Hello my dear modelling friends
On the 28th of August, it has been six months since I started the build on the Haarlem and it is therefore only fitting to celebrate her half-birthday status by showing you what she looks like at this stage.
The time since my last posting has been spent working on the Haarlem, starting the Falkonet Longboat and LOTS and LOTs of research about the future direction I would like to venture into with model shipbuilding.
Starting with the Haarlem, it was time to finish the painting of the hull below the waterline properly by neatening up all joining lines and giving it the last few touch-ups. It is now ready to be finished with a coat or two of clear matt varnish.
Then it was time for the fortuining to be built up. As you all know by now, this is done by laying down overlapping 4mm wide Abachi planks (a la clinker style!). I could not hurry this part as each plank only has approximately 2mm purchase on the previous one - so for rigidity - the glue had to dry and harden properly before the next plank could be laid. In total this little exercise amounted to 32 planks in total (16 on either side).
You will notice that I still have to do the galerij on the bakboord side and open up the last geschutpoort closest to the stern. Also note that all finishing still needs to be done to the fortuining (trimming it to the correct stepped heights and curvatures to accept the railings and ornamentation).
Die semi-completed galerij aan die stuurboord kant laat die kant baie meer "afgewerk" lyk.
In retrospect, six months might seem like a long time to get to this point, but I am very happy to be able to post these pictures tonight. I learnt a hell of a lot - not least of which, was about myself.
Until next time my friends, please take care, stay safe and cherish your shipbuilding!
Kind regards - Heinrich
