FORUMLEDEN met NOSTALGIE......"vreemde" kisten
Status
Wat is eigenlijk een SESQUIPLANE?
(Dat stond in de tekst bij die agrarische tweedekker jet...)
Bart
Ja, dat lees ik ook:
ses•qui•plane
Pronunciation: (ses'kwi-plān"), [key]
—n. Aeron.
a biplane having one wing with not more than half the surface area of the other wing.
Random House Unabridged Dictionary, Copyright © 1997, by Random House, Inc., on Infoplease.
Dictionary
Find definitions for:
ses•qui•plane
—n. Aeron.
Vliegtuigen zoeken vind ik een ramp, maar voor russisch vertalen of moeilijke woorden draai ik mijn hand niet om.....
Antonov An-72
The An-72 was designed as a replacement for the An-26 tactical transport for the Soviet air force, but variants are in use as commercial freighters.
The first of five flying An-72 prototypes flew for the first time on August 31 1977, although it was not until much later in December 1985 that the first of eight extensively revised preproduction An-72s flew. Included in this pre series batch were two An-74s, differing from the An-72s in their ability to operate in harsh weather conditions in polar regions. Production of the An-72/74 family continues.
Versions of the An-72/74 family (NATO codename `Coaler') include the An-72 base model with extended wings and fuselage compared to the prototypes, the An-72S VIP transport and An-72P maritime patrol aircraft.
Versions of the An-74 include the An-74A, the base An-74 model featuring the enlarged nose radome, the An-74T freighter, the An-74TK, 74TK100 and 74TK200 convertible passenger/freighter models, and the An-74P200D VIP transport.
The most significant design feature of the An-72 and An-74 is the use of the Coanda effect to improve STOL performance, which utilises engine exhaust gases blown over the wing's upper surface to boost lift. Other features include multi slotted flaps, rear loading ramp and multi unit landing gear capable of operations from unprepared strips.
Sorry Prop-er maar volgens mij is het geen AN-72. Ik dacht het ook even maar... de 72 is veel lichter dan het toestel dat we zoeken. Kijk ook eens naar de luiken waar het voorwiel uit komt...
Bart
HOLAAAAA
kollega's
FEEST !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:music: :music: :music: :music: :music:
:music: :music: :music: :music: :music::music: :music: :music: :music: :music:
Er zijn al........40.000 .........bezoekers geweest op dit draadje.... 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O :banana: :banana: :banana: :banana: :banana: :banana:
:banana: :banana: :banana: :banana: :banana: :banana::banana: :banana: :banana: :banana: :banana: :banana::banana: :banana: :banana: :banana: :banana: :banana::banana: :banana: :banana: :banana: :banana: :banana:
niet te geloven
prachtig.......
steffe
Verdomd. je hebt gelijk!
Boeing YC-14
The YC-14 was Boeing's entry into the USAF's Advanced Medium STOL Transport (AMST) competition, to replace the C-130 Hercules as the USAF's standard STOL tactical transport. The AMST project introduced a number of innovative features, such as under-surface blowing, which used double-slotted flaps to direct part of the jet exhaust downwards, while the rest of the exhaust passed through and downward over the flaps, introducing the Coandă effect.
The unusual location of the General Electric F103 engines, seen only on a few other aircraft, such as the Antonov An-72 'Coaler' (which flew later), increased lift by passing the exhaust directly over the wing. This also made the aircraft quieter.
The YC-14, as well as McDonnell-Douglas' entry into the competition, the YC-15, met or exceeded the specifications of the contest. However, the project was cancelled before either product could be chosen. The YC-15 would later be developed into the C-17 Globemaster III.
Two YC-14s were built and tested. One is stored at AMARC, located at Davis-Monthan Air Force Base; the other is on display at the nearby Pima Air & Space Museum.
Gezocht o.a. op Ground effect plane. Maar de naam staat er niet bij...
The Volga-2 is an 8 passenger PAR-WIG vehicle, performance tests showed that the operating economics of this vehicle are comparable with existing hydrofoils. The flexible construction is of a light alloy with the use of balloon type structures in order to give the craft amphibious capabilities (snow and ice). The Volga can handle waves up to 0.5 m and can climb a 10% gradient on land. The Volga is powered by two VAZ-413 rotary engines of 95 kW each.
The wing of the Volga has a very low aspect ratio (almost square). In spite of the relatively small and low mounted tailplane, the Volga is very stable. This stability is ensured by the special S-shaped wing section. The Volga is being produced by the Sukhoi group. If you want to buy one, the price is about $250.000.
Status
