Hoi Dylan, ja ik ga er ook eens induiken. Halverwege in de 2e post van wat ik linkte heeft die man aardig wat testjes gedaan. Als laatste zegt hij trouwens ook nog dat met telemetry disabled het ook aardig wat scheelt qua vliegtijd.
Walkera Mini CP Brushless
The Mini CP is awesome with the brushless motor!
It is light weight, powerful, provides great climb out, and has good flight times.
I will not use be using the brush motor again.
Still would like to test the Genius CP brush motor and the mCPX brush motor. Have both these motors but need a pinion for them.
Flight time: - C05 motor w/9T pinion and the Genius CP main gear. Stock Genius CP battery.
- 30 seconds: 4.04V - Power got very weak at about 15 seconds. I had to land.
Flight time: - C05 motor w/9T pinion and the Genius CP main gear. Hyperion 240 mah 25C battery.
- 1 Minute: 3.98V
- 2 Minutes: 3.84V
- 3 Minutes: 3.76V
- 3:30 Minutes: 3.72V - Power got very low and I had to land.
Flight time: - C05 motor w/9T pinion and the Genius CP main gear. Turnigy Nano-tech 300mAh 35C battery.
Note: These are using brand new batteries on their first charge. I expect the power and head speed to stay stronger for these times
and maybe even get more flight time. I will update these when I get several charges on the batteries.
- 2 Minutes: 3.87V
- 3 Minutes: 3.78V
- 4 Minutes: 3.73V - Head speed is slowing down approaching 4 minutes.
- 5 Minutes: 3.69V - Head speed is really slowing down. Too much unless you just want to hover with low head speed.
Flight time: - C05 motor w/9T pinion and the Genius CP main gear. Oversky 400mah linear 20C battery.
- 2 Minutes: 3.91V
- 3 Minutes: 3.85V
- 4 Minutes: 3.78V
- 5 Minutes: 3.74V - Power got weak at 4:40 minutes.
Thrust Test: - C05 motor w/9T pinion and the Genius CP main gear.
- 53.5 grams full negative pitch in stunt mode with the stock Genius CP battery..
- 98.5 grams full negative pitch in stunt mode with the Hyperion 240 mah 25C battery.
- 101.5 grams full negative pitch in stunt mode with the Turnigy Nano-tech 300mAh 35C battery.
Head Speed: - C05 motor w/9T pinion and the Genius CP main gear.
- 5,220 RPM at mid stick 100% throttle with the stock Genius CP battery.
- 5,670 RPM at mid stick 100% throttle with the Hyperion 240 mah 25C battery.
- 5,730 RPM at mid stick 100% throttle with the Turnigy Nano-tech 300mAh 35C battery.
Telemetry:
I have found out that using the telemetry eats up the battery time.
I went from 5 full minutes of flight time on my Master CP with telemetry
inhibited in the TX to 1:25 minutes flight time with the telemetry enabled.
I found the same thing with my Mini CP, 1:25 minutes flight time with the telemetry enabled and
3 minutes flight time with the telemetry inhibited.
My friends Mini CP had the same results as I did with telemetry inhibited and enabled.
