KOLDERSTOK BATAVIA / HAARLEM
Hebben de kraanbalken geen gesloten einde?
Hello Mees
Volgens die bouwtekeninge van die bouwdoos staan die kraanbalken inderdaad zonder gesloten eindes.
Moest even weer bij lezen, fantastische resultaten Heinrich :thumbsup:
Hello Everyone
With a few days of vakantie, it allowed me some time to work on the Haarlem.
The first on the agenda was the twee-schijf knecht underneath the halfdek. As I am not going to paint something that can't be seen, I just cut a diamond-shaped top and that was that. Een gaatje geboord deur die opening op die haldfek en die knecht is met behulp van n messingdraadje vasgelijm op die verdek.
Next was the drieschijf / knechten combination on the verdek. The first attempt ended up in the garbage bin and the second one was mounted with the help of some brass wire and secondenlijm.
After evaluation, this ended up in the trash can. :(
The second one could stay. I am no longer going to say how many korvijnnagels were installed. :rofl:
En toe is die hele oefening op die bakdek herhaal.!
Before the dwars relings could be mounted on the bakdek and halfdek, I first checked how level everything was and if any adjustments had to be made.
All good at the Spiegel.
Op die halfdek klopt alles.
En ons is ook "all systems go" op die bakdek.
So the paint process could be started.
The completed first railing ready for installation. The 4mm notenhout plankje was first soaked in water for about 15 minutes and then carefully shaped by hand and eye only. After a quick drying with the Admiral's hairdryer, it was test fitted and painted.
Wordt vervolg ...
And we continue ...
The first railing on the bakdek is placed ...
... and weighed down by some Chinese-manufactured Coke Zero. (No, I don't drink Coke Zero because I think it is healthier than regular Coke - I just prefer the taste, :)
And then the first one is done. Now it is just a case of carefully applying some black paint to the areas which are now "shiny" because of the secondenlijm.
En dan is die agterste een op die bakdek ook geplaast! :yes:
From this angle, the Haarlem almost has a Xebec-look to her! Just prettier! :rofl:
En nog n plaatje vanuit n ander hoek!
Reling geplaast op die halfdek.
From the Stern this is what the current state looks like.
En n laaste plaatje net vir "good luck".
Met mij bouwtempo het die paar friemelwerkies mij 4 dae geneem, maar uiteindelik is ek happy met die resultate.
Baie dankie vir almal wat volg, kommentaar lewer en advies gee - ek waardeer dit. Dit is dan nou al vir eers - aan jullie almal, geniet jullie modelbouw en laat ons almal ons prachtige hobby waardeer.
Vriendelijke groet - Heinrich
