KOLDERSTOK BATAVIA / HAARLEM
Hello Almal
Dit is nou my tweede poging vandag om n bouwverslag te plaas. Vroeer vanmiddag het ek dit op @ArjenSpiek Arjen se verslag gepost - sorry Arjen! In alle geval zo gaan ik maar voort.
Gemakken geplaast. Toe ek die plaatje aan my moeder stuur - sy is 84 en volg saam - wou sy weet of dit dan "net zo in die oopte gedoen was" ! Die "zwabber-touw"? moet nog gepas word.
Daarna is die galjoen se nagelbanke en nagels geplaast. Batavia experts sal oplet dat ek 10 nagels op die voorste bank het, in plaas van 9. Die nege, het net nie vir my simmetries gelijk nie.
Bending the walnut for the top railing of the galleon was not an easy exercise - even with a plank bender. As each builder's curvature on the bow will vary to some extent, you can't possibly know if you have done it right, until the ornaments are fitted. Only then will you see if your curvature was correct. You will also notice that I cut away too much of my hull planking at the luizenplecht area leaving me now with an unsightly gap. Here, I still need to figure out a plan.
Luckily Grumpy Old Man #1 fitted perfectly on the railing. At this stage of the build they have just received their primary colour - wash will be added later to see if I can add some definition to the faces.
And now the Grumpy Old Men picture is completed! The two kraanbalken have had the slots for their loopschivjen cut, but are just lying loose on the foredeck at this stage.
Question: Are the loopschivjen supplied with the kit, or must they be scratch-made?
Onwards with the nagelbanken.
From the plans, I cut the drawing in question and then glue that to the piece of the wood is that is to become the rack. Photo copying plans have given me one or two nasty surprises in the past. So, apologies for your plans @*Hans* Admiraal - after I'm done building, the plans don't like that good anymore.
I first drilled a pilot hole with a hand drill before enlarging the holes in a further two stages. Even then - the walnut was susceptible to splitting open down the middle.
Word vervolg.
Mooi Heinrich. Hopelijk heb je de nagels dryfit en niet vastgelijmd. Dit is met tuigage makkelijker om ze niet vast te zetten. Je kan het touwtje dan door het gat van de nagel voeren en het met de nagel vastzetten. Scheelt een hoop ingewikkeld geknoopt.
And here are the results:
Half-deck - starboard side.
Front View of Forecastle - Starboard Side.
Front ... or Top View Forecastle - Port Side
Side View
And lastly, a few pictures of the overall view:
And that my dear friends, conclude my news for today. Thank you all for watching, following, commenting, advising, or just being here - it is all appreciated and valued.
Take care out there and stay safe.
Kind regards -Heinrich
Bijlagen
    135,5 KB · Weergaven: 90
Dit ziet er weer prachtig uit Heinrich, maar ik heb een vraag voor je:
Als ik dit lees Heinrich, dan verwacht ik eigenlijk 10 korvijnagels op je voorste pennenbank, maar ik tel er toch maar 9 zit ik nu verkeerd te koekeloeren, of vergis ik me in de pennenbank?? ( of heb ik nog een ouderdomskwaaltje gekregen? )
