Hi Ernst
Even the 155 would offer significantly more power than the engines you have spoken about. The 155 will turn the following propellers:
16x8 @ 8700rpm
17x8 @ 7900rpm
18x6 @ 7700rpm
18x8 @ 7300rpm
This would a signficant upgrade on your current level of performance. I also have a customer in Canada flying a sig rascal 110 ( see link http://www.sigmfg.com/IndexText/SIGRC84ARFB.html) using our 155 and he says he can climb steeply at 1/2 throttle.
The 200v may be too much for this model as it will turn 20x6 propellers over 7000rpm and 18x8 propellers at 8000rpm.
Please note that running engines on castor oil will void our warranty.
Jon[
www.janhermkens.nl gebruikt ook voornamelijk (uitsluitend?) Laser motoren.Parrot kijk eens naar de website van Jan Hermkens, daar staan motorberekeningsformules op. Jan kan je ook een handje helpen als je dat vraagt. ...
