Ik ga beelden van mijn FPV camera + OSD opnemen, maar ik zal je laten weten hoe het bevalt. Even wachten met bestellen op de hobbyking website, de prijs gaat dan automatisch omlaag naar $48
Op youtube vind je ook veel duidelijke voorbeelden.
dvr hobbyking - YouTube
Hier nog wat info over de gebruikte sd-cards:
sharon 3 points - 12/24/2013
i have few questions: what the size of sd card can I use? how much recording time it is? does it start recording automatically? when the sd is full does it start from the beginning? thanks Sharon
JCMegabyte 86 points
I have used up to 32GB in mine. Faster cards (such as class 6 or higher) are better. In the best quality mode, you'll generate about 25MB of file per minute of recording. At this rate, an 8GB card should provide you with several hours of recording, however, I recommend automatically breaking up your recordings into smaller chunks using the DVR's built-in menu. This way you get files which are much easier to deal with later, and they go back together seamlessly if needed. Happy holidays! =)
I forgot to mention - you can set the DVR to start recording automatically on power-up, and also to "loop record" by deleting the oldest recordings to make room for new ones when the card is full. That way, if you let it run continuously like a dash cam or security DVR you'll always have the most recent activity on the card. Cheers!
hoi laat me even weten of dit goed werkt :lol:
en neem je dan op via je fpv camera ? of een gopro oid
Nick
