Nieuwe Fatshark Dominator lijn ( v2 en HD )
Discussie in 'Multicopters FPV foto en video' gestart door QuadRon, 3 feb 2014.
  1. Afiso
    Afiso
    19 nov 2012
    Amsterdam
    DominatorV2 - THERE IS NO DOMINATORV2.2!!
    There has been a lot of confusion caused by members naming the re-released DOMINATORV2 as V2.2. Let it be clear from the manufacturer's mouth that there is no Version 2.2; there is only DominatorV2.
    The originally released glass optic version was recalled almost immediately and literally only a handful of units shipped. About 150p in total They have all been recalled or accounted for (a few people liked the larger FOV and didn't return them).
    The only DominatorV2 in existence and in stock at retailers are the improved optics version. The DOMV2 sells out almost immediately. No retailer has been "sitting" on an old unit for 3 months hoping to unload it on an uninformed individual. There is no need to ask the retailer which version they have.
    To the valued forum members, Fat Shark would greatly appreciate if members could simply refer to DominatorV2 and avoid using the 2.2 convention. Lets just pretend the glass optic version never existed - its causing a lot of problems for the retailers. That said, I will be deleting any thread, post that references the DOMV2 as anything other than DOMV2. Thanks for understanding.
    Ff het topic onderwerp aanpassen, want ik zocht me zomaar stuk naar V2,2 :nosmile:
  2. BorisB
    BorisB Forum veteraan
    16 mei 2012
    Brabant
    de benaming was alleen handig in het begin.
  3. Gerard_nl
    7 sep 2002
    eindhoven, El diablo.
    ik pas het effe aan
  4. Tom Bollongino
    Tom Bollongino
    24 feb 2004
    Weesp en tevens praktiserend praktijksprakker
    Ik bedoel een foto als deze.
    Ik meen dat deze vorm van de oudere Dominatorserie anders van vorm is.
  5. BorisB
    16 mei 2012
    Brabant
    Volgens mij zijn ze helemaal van hetzelfde vorm. Heb ze beide gehad en enige verschil is dat er nu meer knopjes boven zijn en dat het stuk bij de lens totaal anders is.
  6. Tom Bollongino
    Tom Bollongino
    24 feb 2004
    Dat bedoel ik dus! Als deze vorm waar de rubberschelp op gaat anders is, dan past die skibril die ik kan kopen dus niet! Zij werken met een masker -zie filmpje hierboven- en als de vorm anders is dan past dus de nieuwe Dominator V2 en HD niet. Dus voor ik iets voor veel geld ga bestellen wil ik zekerheid. Vandaar mijn vraag.
    Wat duidelijk anders is is de gleuf van de microSD en het gat van de LED. Dat kan ik zelf wel aanpassen.
    Wat ik zie bij de te kopen bril is een recht stuk ipv een ronder deel bij de nieuwe serie, daarom hoop ik 2 foto's naast elkaar te kunnen leggen.
  7. robot
    robot
    31 okt 2006
    heerhugowaard
    Hi guys
    Ski brillen uit hong kong zijn veel goedkoper
    Wanted: Ski goggles to cover glasses for Fat [dom ] and Shark Aviators
    Dat lens idee had ik al veel eerder
    Werkt niet goed
    Lens moet 20 cm breed zijn
    En je hoofd heel klein
    En dan nog zitten lcd s veel te ver van je ogen
    Dat 6 dollar motor brilletje werkt veel beter
    Er past gewoon geen ski bril tussen fatshark en je hoofd
    Al honderde uren aan verkloot
    Heb 3 behuizingen van fatshark gehad
    Lukt mij niet
    Rob
  8. Gerard_nl
    7 sep 2002
    mijn vraag zou ook zijn,
    waarom ?
    de farshark op zich werkt toch prima.
    waar zou ik die voor in een skibril willen meubelen ?
  9. Killerbean
    Killerbean
    18 aug 2011
    Ik vind dat een ski bril veel en veel lekkerder zit voor lange stukken vliegen.
    Dan bedoel ik 60 - 120 minuten.
  10. robot
    robot
    31 okt 2006
    heerhugowaard
    Jup het zit erg zacht
    Maar denk dat bril dragers er meest belang bij hebben
    En fs past lang niet op elk gezicht
    Moet je wel wereld wijd bekijken zijn zoveel soorten mensen
    Gezichten
    Neus die hoog of laag zit
    Of te groot
  11. BorisB
    16 mei 2012
    Brabant
    ja zie je vaak bij long range vliegers.
    Zelf ben ik blij met de huidige pasvorm.
    Hebben jullie ook nieuws gehoord dat er HD v2 uit is?
    Deze keer scherp
  12. Professional555
    Professional555
    15 jan 2011
    Dan baal je wel als je er al 1 in bestelling hebt staan..............
  13. Killerbean
    Killerbean
    18 aug 2011
    Kan nergens wat terugvinden over een hd v2
    en het is nog geen 1 april
    en ja ik zou balen want mijn hd is er nog niet eens
    Weet wel dat greg bezig is met een zelfde soort bril en dezelfde resolutie, maar dan 40 fov en wel scherp beeld. Kan me niet voorstellen dat die nu al uit komt.
  14. Tom Bollongino
    Tom Bollongino
    24 feb 2004
    Ik vermoed dat het de gewone HD is met een kleine aanpassing.
    Fatshark heeft zelf aangekondigd dat een nieuwe HD niet binnen 1 jaar te verwachten is aangezien het hele binnenwerk op de schop genomen moest worden.
    Zoiets als de Dominator V2 > nieuw optieken V2.2> te noemen V2.
  15. BorisB
    16 mei 2012
    Brabant
    Dit is toch echt een v2. Als je kijkt naar de google plus pagina van de man zie je dat hij voor immersion/fatshark werkt :)
  16. Tom Bollongino
    Tom Bollongino
    24 feb 2004
  17. m00st
    m00st
    1 sep 2013
    regio Den Haag
    Het is in ieder geval duidelijk dat Hervé een goede band met Anthony Cake (van ImmersionRC) heeft, zie hier een video van maanden geleden waarin Anthony al een demo van de Vortex geeft, opgenomen door Hervé
  18. DannyMetall
    DannyMetall
    14 jul 2013
    Z-Limburg
    Je kan van mij (ook van Boris ) aannemen dat Herve voor IRC werkt .. :)
    we staan in nauw contact met Herve en IRC
    er komen nog veeeeel meer goodies :D:D maar mogen daar nog niks over zeggen
  19. Tom Bollongino
    Tom Bollongino
    24 feb 2004
    Ik zie daar een kudde vrolijke jongetjes die haast ontzettend blij zijn.
    Er komt dus wat leuks aan.
  20. Professional555
    Professional555
    15 jan 2011
    Goodies
    Laatst bewerkt: 5 feb 2015
