New homemade bullet outboard
A new outboard drive is under construction! This time is a bullet drive with a 4mm flex shaft in order to handle the torque of a 36 mm motor. Again the end piece of the flex shaft will be based on two ball bearings.
The building technique differs from my previous DIY outboard as you see in the photos below.
Chopped CF with epoxy resign to make the hydrodynamic shape of leg and strengthen the construction.
Then sanding, putty and maybe fiberglassing the whole construction for even more strength.
To be continued....
Wow, nice project! I lost count of your ongoing projects, but it doesn't matter, I like this one [emoji6].
How did you mount the fin below the flex shaft? Did you cut a slot in the brass tube?
And I also wonder how you mount the ball bearings and how to prevent they fall out?
I like this way of modeling, using just hand tools. I have some ideas for a DIY outboard as well and the chopped CF is a really nice method!
Thanks Jan!
Having already some experience from the previous outboard, this time things seem to go really fast. This is a 3 day part time work, a couple of hours in the afternoon. So I believe it won't take long to finish this one:D.
You are right Jan I cut a slot in the brass tube so that the fin anchors in the main body of the leg.
The ball bearings are secured with Loctite. It has worked perfectly in my small outboard.
I realized that the chopped CF or Fiberglass is another way to thicken your epoxy glue or resign. I also used chopped fiberglass to thicken the epoxy glue and the results were great. ;)
Wow, great work! How do you cut the carbon fiber? By jig saw? And do you wear a mask, or use a vacuum against the dust?
I like your hand sketches, very 'engineering' style [emoji41]
Thanks Jan! :)
This time I used my dremel with a disk to cut the pattern and then sanding to make the two pieces equal. Every now and then I stop to clean the dust with a vacuum cleaner and of course I wear a mask with filters. Then, I clean the surfaces and tools with alcohol because they are painted black due to the dust. It is not the best thing to work with CF you get messy.
Oh that is a compliment from a real engineer;)!
Well, this was by far the most tricky part of the construction, but I have adopted a number of innovations:
1. The hinge pin is based on two ball bearings for literally zero tolerance.
2. The angle of the hinge pin is unchanged when you change the angle of the outboard. For the advantages of this property and a related discussion you can see: https://www.intlwaters.com/threads/another-lower-unit-option.81251/page-3#post-809409
3. The outboard will go all the way up if it hits something in the water so as to protect the transom.
Some details
To be continued...
Wow, great job! I know the discussion about the hinge pin angle. I'm not sure if it is noticeable for fun boating around, but it is certainly nice that you adopted this.
The assembly looks very professional with al the bolts. Did you glue the bearings in the outboard adapter with Locktite?
Looking really good, great work Dim [emoji106]. Regarding motors, I don't look much at Amp draw and Watts. I look at the size and the kV number mostly.
I guess there are 3 classes of quality: medium (Rocket, Xteam, SSS), high (Leopard, TP) and premium(Neu, Hacker).
Amp draw and Watts depend on the motor efficiency and the voltage applied. Also the efficiency of your setup: shaft, prop, hull weight and size etc. Too many factors to take into account.
That's why I look at what is used in high performing hulls (I guess you do that too!). And try to use that as reference.
Thank you Jan for your detailed reply :thumbsup:
. You made my choice a little bit easier and I decided to harry up and order this 3670 2280 kv motor at 52 € (including water jacket and shipping) because there were only 4 pieces left
Let's see how it performs and how durable it is. :)
It looks similar in construction as my 4092 1250kV motor from Gool/Seal/WTZ! I am very happy with that one!
I think many brands come from the same Chinese factories.
This is quite a bargain you found!
