Wat is het verschil tussen de Tigers t.o.v. de Cobra die jij nu gevonden hebt als ik vragen mag?
Here are some facts which you might or not know already,
1- What motor can it take?
A: From 28-35mm, Phantom size motor works perfect, and 35mm motors with around 950kv will be the power house.
2- Props size?
A: 10-11", however 11" is a maximum size this machine can take
3-What lipo can i use?
A: 3S 5000 UP TO 4S 3700, with the size of 29x50x145mm.
as an example, Gens ace 4s3700 is perfect for this model.
4- What esc can fit in?
A: 40 Amps Sky hero will be included in the FCR version, and
any 40-50 amps with size less than 28mm will enter the arms. otherwise it have to be located in the body.
5- What is the weight of the machine?
Barebone Chassis only is 480 Grams, the FCR version is 1130 grams, not including Flight controller and Battery.
480gr is not the lightest machine, but definitely a solid one.
6- What Flight controller recommended?
A: Naza, Multiwii, Pixhawk.. basically any thing goes..
7- What is the flying time we can expect?
A: Tests done with 10" props, Go pro, 28mm motors- gave clean 14 min of flying.
8-Angle banks can be seen on the image, what is it for?
A: those are 15 degree banks, which are an option, and can be a good fit for FPV and normal flying, it will increase the angle of attack when flying.
there is delay with 2-3 parts, I think 15 september will be correct time of delivery
Die Replay XD 1080 MINI wurde komplett überarbeitet und neu abgestimmt. Das Beste aus der XD1080 und der XD720 wurde in der neue Replay XD 1080 MINI zusammengefasst. Mit nur 24mm Durchmesser und 85mm Gesamtlänge sowie einen Gewicht von ca. 60 Gramm ist die 1080 MINI einer der kleinsten und leichtesten Full HD Kameras am Markt. Bestens ausgestattet mit einer Auflösung von 1080p/25 und 30 fps oder 720p bis 50/60 fps, 5 MP Fotomodus und Time-lapse Funktion, einem neuen 120Grad Glas Objektiv, über 2 Stunden Akkulaufzeit und einer Wasserdichte von bis zu 3 Meter.
Replay XD 1080 MINI mit dem LowBoy Mount und der Flat SnapTray Basis Aufnahme. Gesamthöhe nur 35mm!! Montieren Sie die Replay XD 1080 MINI überall. Die geringe Größe macht es wirklich einfach die Kamera schnell und sicher zu montieren. Mitgeliefert werden 1x LowBoy Mount, 1x Flat Snap Tray Basis Aufnahmen für gerade Flächen, 1x Curved Snap Tray Basis Aufnahmen für gewölbte Flächen z.B. für Helme, und eine 1/4" Mount SnapTray Basis Aufnahme. Die 1/4" Mount SnapTray Basis Aufnahme kann mit allen unserer z.B. RAM Mounts oder Ortec Halter mit 1/4" Aufnahmen verbunden werden, somit sind unzählige Montagemöglichkeiten gegeben.
Valt hier wel mee hoorOngelofelijk... Jij hebt echt wat geld teveel volgens mij![]()
