S
SCRT Pilot
Guest
Bespreek hier alles mbt de setup, het bouwen, onderhouden, rijden en racen van en met 1/10 elektro F1 modellen.
Oude(re) modellen mogen natuurlijk ook besproken worden
De discussie over het nieuwe samen te stellen reglement kun je onder de volgende link vinden: een-goed-1-10-f1-reglement
Hier de nieuwe modellen van F1 auto's.
Corally
Corally F1 chassis
Corally F1 auto
New Generation F1 -*DUAL COMPOSITE features include:
HPI
HPI formula ten chassis
HPI formula ten auto
The Formula Ten features realistically scaled dimensions such as wheelbase, width, tyre size and more, allowing you to faithfully re-create your favorite team or driver's livery and do battle with rivals out on the track. There is truly nothing like the excitement of seeing a full grid of formula cars painted in replica colors, waiting for the lights to go out!
The amazing scale detail starts with the awesome 6-piece polycarbonate body, which features a variety of optional winglets and barge boards that allow you to re-create your favorite racing team from many eras of modern formula racing! Optional side pieces allow you to have flat sidepods or a sculpted rear end like the real cars. A scale helmet is included, allowing you to copy the helmet design of your favorite driver or make your own design.
Front Wing
The front wings features all of the fantastic shapes and curves of the real cars. The unique dropped middle section, upper bridge element and multi-level rear elements are unique to modern formula cars, and are as distinctive as they are on the full-size cars. The 'bridge' of the front wing can be removed for a different look also.
Rear Wing
The rear wing is completely realisitic as well, with a mouled-in diffuser and rear crash assembly for total scale realism. The front and rear wings are injection-molded, high-impact plastic pieces work as bumpers and as functional aerodynamic devices. They definitely won't come off as easily as the wings on the real cars! Optional nose pieces and wings will be available that will allow you to replicate a variety of past and future formula cars.
Removeable Barge Boards
Just like on the real cars, the functional barge boards on the Formula Ten direct airflow around the sidepods. Held in place by two steel screws, the barge boards can be left off the car for a 'cleaner' profile or a more retro look, to reflect the design style of formula cars from the 1980's and early 1990's.
Optional Winglets and Chimneys
One of the most distinctive visual markers of modern formula cars are the various 'winglets' and even 'chimneys' that aided airflow over the rear and around the sides of the car and rear tyres. The Formula Ten bodyshell includes the pieces necessary to replicate the unique pieces of aerodynamic aid.
Slick Tyres and Multispoke Wheels
The tyres included with the Formula Ten kit are molded slick tyres in a real rubber compound, at exactly the right size and proportion. The wheels are made from high-impact nylon and look just like the actual wheels the full-size racing teams use. HPI also offers a variety of optional officially licensed Bridgestone Potenza tyres in Medium and Soft tyre compounds, for tuning and high performance racing applications, plus a set of silver precision wheels for a different look for your scale racing team!
Specifications:
De HPI kan geupgrade worden met bijv. een kogeldiff. en Bridgestone Potenza banden:
Bridgestone Potenza tires:
front soft #102906
rear soft #102907
front medium #103016
rear medium #103017
Tamiya
Tamiya F104 auto
Andere merken en typen? Plaats ze snel in dit topic zodat ook deze besproken kunnen worden.
Corally
Corally F1 chassis
Corally F1 auto
- Fully equipped with super strong hardened black steel torx screws.*
- The precision chrome steel front and rear wheel bearings offer long lasting, low rolling resistance and efficiency.*
- Super lightweight and user friendly aluminium inserts are used to replace normal nuts.*
- Unique 1-piece*dual composite*rear axle with ball differential.*
- Super tough and strong*dual composite chassis components with pre-shaped battery slots.*
- Super smooth rear suspension using 2.0 mm*dual composite t-bar with 2 rear tube-dampers and shock absorber.*
- WC front suspension as used on the World Championship winning SP12X.*
- Duraluminium servo mounts.*
- Super rigid duraluminium motorpod using unique tube design.*
- Front & rear adjustable ride height.
- Threaded body posts for precise body height adjustment.
- The ‘US Standard’ 1:10 wheels run on lightweight duraluminium rear wheel hubs.*
- Rear Width : 204mm.*
- Front Width : 198mm.
- The F1-NGX comes partially assembled. #TC 00141 CORALLY NEW GENERATION* F1 - DUAL COMPOSITE
HPI
Front Wing
Rear Wing
Specifications:
- Overall length: 436mm
- Width: F 176mm, R 180mm
- Wheelbase: 283mm
- Weight: 1050g (approximate)
- Camber: F 2° R 0°
- Caster: F 6° R 0°
front soft #102906
rear soft #102907
rear medium #103017
Tamiya
Tamiya F104 auto
- schaal 1:10
- F104 chassis met achterwielaandrijving
- nieuwe velgen en banden
- PC karosserie met optioneel aan te passen side pots
- Elektromotor van het type 540
- 3,2mm vezelversterkte kunststof bodemplaat
- 2mm vezelversterkte topplaat
- RVS achteras
- In de lengte geplaatste accu voor een slanke karosserie
