Decathlon 2 m herstellen
Beschadigde Decathlon 2 m gekregen
Neus weg
F3eGm1bnolZvqxZSmcOWs4VOnfxXF2bM4J9XULF2FsM2JsIimNLn9d3QJJGb-5ExcBaLc6vy4UVUucEQ7eJ9rAWEzMAPJh9HNtuEoixzQUWXhyOj125t0uy3rXqjJaeFtIpuEuFYdqDnwOgAbZweCZMHwHDXOXOK_95LygD7UthjFp1QB8bbuctOc1kPaAi6UMTTv6AiVytHZtHH7tvvkWrg9PNsJUR9aTd0GDTCY3OjmsGO2YA1fR7ZFwLU2lTSEGO4xeqltt1un8PpdH_0Pqx_Ocx6op5MoCg0VDRHlCCWPcFj-1fXwaDgnv55FGyEI2qAMQ4_G3F9yZhgUxH6c_2LKpcbjChb0BjS7KJQeL0klz5LEmpOQrOyh7gvj7S1uZZTNiCrh7UKw8LBMr_gOF9ETjtvjhQXjm_moE72wADXwFijhJlWl9XU6g_XDcLyR-INn3sC1sXJEtyMuxuIc6_3TngSmWwtjNEoGP5PwvQYRlJP63oJWb5X482Addt6hUYoM0mQHWKJA8Q9SOLPjakF61HNjTqZrlZbqqkguKOSViIIQAtmNLgreA6ifgfO4xEUOtK8NM3VFHRKZLVcrc6vOcJDFpvm85lsIT_R59dFSxj2-EmGklNa2mLJ1P6NEyaonp5X9-bOEEgSd_kOHaCOCREw75s=w1242-h931-no
Rug gebroken
GAyrIPI59lo6IVFUPKWC7nYyHmv1ymbgVj29mj5raKwY9bb12BLzJo90e3Iaw0gHSS9YSYIXxRsKAGXd_z-QRubugiHYPs1N8TuEf4WO3MboGD8gVlTruTe0ocO0dUAU82F5adpkmF3je9661q9_0IESJb3Xxs9nSzrNFMZwSNxIvFIVgoWGNESMs2TYFNM4gMkEuRH9n8V_QWbQ81LQMjkgFDIYk9Swd5pIQiPN12a2o4n4ySNULoPV7hyrXsswvBcdpZo1rYjnaaP98860cCcQCV73QVPmCqdWVhubjw_ySKn7bJhNjX2vM2hq7bYOTZryWKiCwIRTYhU52zYQspjf0nZi2cbUk43S6oqHGUeXlgiYREX2XstW15htjR1deGxn1ZUaeMF9nMBtRN-FeP4edj8iAjHSEZcCT8QACIoSxImA4ZTCRJzsDaGG6MPcYV0hLvI8IkDcofH6DJ5GbbqkRH7CZ294lo36q2imeSHrxSRtPIfxm5Rw-hovLjHdOEPZyno-0up3NX5CPugAw2qrzd5CP3LsAB7dihmSE4Yq62g20gypLx8yXE8rGCNq0Z4sMu80HE5zdmJcFBzEeQnmz68uA2VKFN14oBbGB285LbQyxeEO0BSemZcKHwJcOIoad8jPGtb8ghcBEOhzXVZyyTAZrms=w1242-h931-no
Wortelrib terug in vleugel gelijmd
Strut bevestiging uit vleugel getrokken
uFC-IvQBNpfbnXHUZYEfpnJjESNmumw1K_wZTOOznFWLqcAEDNdxItJv09FIwnQAzqQ51ypOMuRuJTV2z2mmd9WVgtr23M_4tEPgNBxxnIDG1WuLmfXv_0oa92chrQ_0hbzlCcrPwm6l0q9PD05HGJt_8O2qV3DL_6h2KClM3Y3FMAhKIkoEgV9PRZYW6AIzpRVz4Y6_dLl7y60uXlQS96jIROQZxi1PbgzngAFUtG-sh6IqUmkJKarggbhpxkGyABP4xxdTQF9xFH2kmZFIgcDnBsPlIRkPrsUKtQva0tfdsoZjlpqhixu7j3zSnYoUfYJgFvFXpG4DZM3j9K2aKVWRr9ZGXvQXP2c1h2RwhaaqFhNWD4x5mQjrLLdQvq4XflQu-9E89aTUirge2K-PrsfhXMFZ1H7jXrw8e67gES-zhHulFV9QtohlsW-g4ZbG1HcXy6MpiuwdTPQRQZ_hXS2YBw04_vh-S2FQkHwjYV1XKpB2SXnYonE6H2gEFl6sKWrJiAMdpr6wtk8AaJaZI0spPOhQn_AFcoDW8-4ANseDntZr9ydAvKHpSFeGBu0EoC14b6eH7ceaSqfd0Am5qWhKOV_iFX1jtZhZH8E6PY6GHXNIcZ3viZwjz-zEDvf_GHl-K2rvtiSnURBxejgAVlBY3Fi8Zs0=w1242-h931-no
Beschadigde opening opruimen en 2 onderleg plaatjes inlijmen
GhpnrRSrm7k3ct8MWAAqmFtrqSHd4jfBp5RQnpBh7srqj0PQ3jim14_HHcINZnM0Yw_APqkoCgqcuexCLQh0m3v7P3J22JPo43apfqmTuls0P73bY01NNa_V98y9k2giRDyFd-tejMIljrd9YAUrHrA2WXO2vDc8umif3Rvq2jDv7lgcPIIJmpUru9Glv4PE_BbKrKodP81S8xgKttF2v50Zgo970IqRZqoeyK3x9bQdEOV2dba52dSIv3gLPOPc43au1YsI7_TE8r1tZ9EDRoNliJhjTh3iRoepC8mJ9vsOeoE0ckBn8dhmsu_xIT6ViLpxlF9hPbJN8jJ1iP7zimvtVOw_llDgYefs70qMlrMeGUUpeo4IIS1EiOmlUFh-7F6XEe3tWc7zw7LMzb7Da1h8Lluy6CCuR__hzE8lA7s8R4aSBVmYGSxhBFWre-LbIbKn_FBT9sO51qp4TNA8jS_tQSoxVHUmcTnPk4Jbw215Je50om_wEzLvm1LG0_jhyscZDMYqIhvwlTOTqdHi6xeYbCYbSSum_UsdLKHeFEJ0A1k5OrEJ79l5mjU9a8dG8Q-OQRrskJyufJVGrCBhPF71Xxn0grbhfe45JdJ9MWMG9lDox9LiXKDpO-RspyaLHshf3dD5Xp-rWuO9iODZ8u1Lk_StxXxgPxwHlakuGOMXUBzJX4qTVEV_hpfY1U5GEg3ArQY-SsU8puHvUJsjQDz9=w1242-h931-no
Versterking strut bevestiging versterken..
cHLW72x3PMWWVj3s52Sbljalx4aHnFX2Vef8FmFFyCvd6CKOnEDTCk3QcDFSl2DVo_f9GLilU0UJDgeOBacYBFG2OzNlbyExc0BPrk5Hl461xSUlqUQsDLjCI8By27W-U-YnX5HogdvIZvx5gvI7lDqN5I0RbRIDTIKvmOvMNHbH_2oB7RklC2aHJpkx2nuiIxe0WBAVjZ8SEl6HnTpzTKfLTD9yd0TpEsKH7Z90LXspmDpUsp8ts1GuSmlRgwzSCD96YpWQ7jx94FbjsOW6cVoRD87_Y1fwYhpeEqkXDnqnJRVKuiC6Uk7UHLe82Nvwmc8qpwCv9Zzn9EKGgiMXINXee315_2_nY7iugUPCUOMVvwR3wkzbO1TGf9zl7cWzGfvHUyZAneL6HYY3CWFXlACHXEe7nFScjquPmZmg3PUbZAugEf7a5CrBRUo8W4e6ldKnRu2tBIdNRnx9B4yIHge85IxM4BcEi33jNQUb_rtu940k2ldYLOn2IbDElS2MMBxaKj4c6lHBI3IoBnPW1kJIEkYujTw9SJ2a2wMNNKxXz-ZpCA6HxgjQKw1oY5dYNyqGq1wWPSL6RXeOsqES5mdglKn1Y92dScwrHvKe1znNwyiw6j_RS-8J6xJLHo5_T0wNx7lEwjdRA7cIQiG-2TODpymrjBU=w1242-h931-no
Iets wat ik niet kan herstellen, de vleugelbuis 3/4 " 19 mm.
Waar is dit te koop ? voor kleine lengte
Aan motorkappen is ook wel te komen.
Als je de producent weet?
Een bouwtekening van een vergelijkbare geeft weer meer inzicht om iets nieuws op te trekken.
Dapper werk, maar ik denk dat je met al je inzicht er weer een patent model van weet te timmeren!
Ik volg je verslag! Top!
Blijf die reparatie klussen altijd leuk vinden, even lekker kijken hoe een ander dit soort zaken oplost:thumbsup: succes.
Ik zie een nummer op de wortelrib staan.
Staan overal in het model nummers gestempeld?
Zo ja, dan is het een Pilot, maar die maakt geen 2 meter kisten.
Maarrrrrr, ze gebruiken wel 19mm carbon buizen.
Het snelste is om even contact op te nemen met http://www.baorcshop24.com/
Dat is de importeur van Pilot RC en hij heeft hele korte lijntjes met Tony Tan, de directeur van Pilot RC.
GJ
Bedankt voor het meedenken.
Achterschot staat SEA 83
verschillend onderdelen met NR
Vleugelbuis is alu 19 mm dat is 3/4 " vind deze wel maar leveren niet in Belgie:(
Het is ook een flinke lengte 73 cm, waarschijnlijk omdat de vleugels zo licht gebouwd zijn 499 gr stuk 91.5 X 35 cm breedte romp 16 = 199 cm span
De motorkap is nog te redden, paar scheurtjes.
Motorschot is nog heel en een zakje met alle stukjes.
Leuke 3 D puzzel :banana:
Handig dat ik niet zelf hoef te craschen :D
De 19mm buizen van Pilot zijn 72,3 cm lang, dus dat kan wel kloppen.
In het verleden hebben ze ook alu buizen gehad.
Maar die man in Luxemburg heeft ze gegarandeerd liggen.
GJ
Het is een Decathlon van Seagull, Of bij Lindinger van SG , beiden het zelfde modelnr .Manufacturer number: SEA83
Heb er ook een gehad, met de zelfde schade, maar na een nieuwe neus vloog weer als vanouds.
Leuk, ga dit volgen.
Rido.
Vleugel hersteld en stut bevestiging gemonteerd .
55S5pxNhgalSYxCXNta8ycmE4ugoLsltz6e_Anyru_ubamyQhrJj1H5YXLOJR09RM42NvytUr_Aci4UlPQSbWWI-2Oh_T5wYel8horJKBsA5RDXXVFgSHzvCXcsWs0VwKmyWDnqbMosu19sjW-UcE0Z0lo79KxvF5mlirkj_70CGAAfwzEkKJEFPODUDuoLl04H08kpEG4vVNiDAtmpM-6aHybAoG9qga6D5S6jOktLc2qbQ61eGYpDbYxMcCVtxlutDvcooNQeNTyidQW5mnTMeraet-hd_CkBWRHrBDRW9Kfm4ToxpRsXUVLak7ojh4QuZ1rTQfLN6nlF4sdDZmWXHK1ELFsMuA0mdBnJz1Q-5xYEjny7thBsuEYDJ_OgJ1Szs4NdPbecClLl6U3X4zanLVqdSggfQfFfo0cI6e7TNEWNrc3wqp6jUXjWR56ot-Do_jXDg3a-hciU8fX_obDs5xeKhYRH6fDmhil60chzlyjEfr5PuQVnsHXZXzGDI5km5-HCiZTcGYqCDMF_dIYmJmnkW0OLznTkLI_WZzNOVxnU3LR26-JUC8WXbRag6HcPOfPcvwOKBhRRSxXQbgHh62bG-JVlJ-juMI4XY-En2FqKTYCHpf__X_XFuMCFLmpefbL2s_BpabODXRqvnFGDx3dRvQ0TyqyKFhrPQp0FryHlDl0t1ULvxUjTrHD-gkSm2gdC3NOWBCN2VUieyHVCZ=w1242-h931-no
Gebarsten zijflanken met triplex versterkt.
Bovenkant achter schot hersteld
ernm3eq8VJ3Pv3DN6t2M9BZKjigs9yRq3Sm0DwfO3S_B1Ga1I6t-HZsYk6Lsk0uRenl_9Qy9nHnt4nl9tUVWWHdt0lW38h7OGWDyiNgf7RzBW4XNalx6qxOqL66UCVukOEHpeI9G9p9ZbrlmJv0bmWzNAQYvG-ghwshSIF6Xb2l766STAszT0kPzSLqFF3OKJ8PE-I-RAZhBaYF53NEH2OU4Yv8mogMmjj-kh-r8OTcHgZB0WbNRPmTOIL1oSMmtAoiu7_oC33v-3bLcug5bplNbooK0jZ_6JPUYXSYQmujJ5OfwY7ioZRkOrIYcmydvXSKVjSUg5xsfbIMHeewllFWRAp8uxtibfng3LSU8YTJ8f23XfOQMLmJkUjDAAJowBe69UoARYeQF-RBvLHozI6JLfN4h-TuUr3DHR8SSpHPq616cn9ianO_1IZ-k6HT0B2nFJEWPKUNGENbZBvI-4yLnBJLGMQ_a8vHobJVmGYS-Hwzi1nv2P535IKO3nvkC59zp5-CxCb5shMt_GKwbPSkZ8nCXVgK34BDHszrmIt5SfUhxkWHE3Mr9U6AjNOTixQVZLxenw6w2q1NaDPraf5gO1Y2vHl6mH4xBt_PIir6vBnUOvVUqJ_MjUpDyTI8FtmhAhlqkTNPYdbi2-SkUfUkXnrs_sce-eevwHGGRraqiB25tG2F9qHbwRXi4e4q61f4N72XQU_HupSZPtaBKG0VH=w1242-h931-no
Nieuwe voorflank in aanbouw
8cGwdiYQRiPoAG0IW1nsZs6HW04vS-QFHoF66i029tS-K9G19qeMlI9IjF16bP_0uvxVS4ToYFMmoGSmzii3fx-KtXWixeivDKgJEPaeyKQyiIZJW6bsFcBYNaqTRwe_WBGl1bacpDwczuqy9z7gJ9i2nh87gvWssB5ICbuy_9IZu6kNjn5tpU9o0daX-SXiPU2ywhjk3mdaG0MD37-9n5Gr7TXZm8chk1COuc_v1LCRoT6atntmCQT7al5Fi7_iHrFsKrHzYp6ZRR7AVoH2IXChfk8mLrl66n0Wg-qOjvVjfR4z6lyl2tNetkiFJsAQ-7Waxq4K_2bLE1LjriJp2IgyPDTWFGfY4JvyQlFiSQmlGLicjpegAqsEG_FioVVDAZHT8XCAjZv5aUMrow7UV4AkMoYKLxPti9yK4jKzQ-a3o7i-hNJ8eLMf_A6osggUhhq6l9_IO1cXiUrH0y5875AY7mcCPe_m7UGwTAYqbXpxfPTB9VG3kIYyFqcS_QitTCnh5ft42vAjX08pUdsv7NK3ngCF-_ImP0kRScKo5b-djppBrGySw7diwMvRdof416BksJ6BIR9ImRoRB9DhEOaXfjyYGeiZ3mBqalQSVXu9yF5uz2AkCvR-kYsp_0eM8511zp7fxK1RujnVbbgDRBgM4RqBENIFlP0XkTU9dUtS4G7eJ89RdA_QYKdZSShGKr9mWCzscVdULAQp9lWAGh-D=w1242-h931-no
ziet er goed uit. spanten kunnen nog wel lichter dmv gaten.
persoonlijk zou ik een fijnere zaag gebruiken. ziet het er wat netter uit.
waar de romp samen komt bij het oude deel wel iets verstevigt?
mocht je tzt stickers willen hebben kun je mij een pb sturen. van de registratie enzo.
Bedankt ga ik onthouden :-)
De rafels in de gaten zijn van de gatenboor zagen doe ik met een wipzaag met fijne tand.
Dat nieuwe stuk is 20 mm op de 8 mm multiplex versterking van het landing stel gelijmd.
5 standard servo's ingebouwd en bekleding klaar.
Motorkap is al versterkt met epoxy en glas, nog verder af te werken.
Motor nog inbouwen
Xd6XWMhWSIIzyid1C9ByuNnUBSIfrRQMElYgMrDS0Sow_gbgwJJqFcUb2ZzGykCAw1XxPPA6aj9xFyPGNhz3PW8e7hpCz9yVHKdjb4ZNTie_kwm95Tk_naCFMAJF8nEZ4NN4XB2qU738BqbzDH4PU454u4ahY53M6k3XaVTRVHtLgoJ-9et9B4VW9qYataxHkD2IUsM5qAOD9z1QZ3w8kJL1AagEp1nVBtguZaGAwj0-nYHzwAOL0q2ZKcNQtCUhOKUbuckwfgjVfAFAPtHUieHVeNHozTfE-fJxaqEFQtUd0WodsqCgMGEZ5rsY8EH3uK7OqwE0kKLlGVpOxHAbtmysfks2S_sIDhCPbGpscrh5uSjLumACzxT0w17M25c6Op8Pp-cp1o7syDZJz4rVcOiHop9UzeGFsWe-tMTx7RogPDVfgUV2Og7SZRcKq4qglTDqXsr-VVivcTrVgT_EjXU1dsgUXpXSeyFrn-E0N1OjH25YF6Mx3l0-EhhozWU84H6CLxb7Cem96k_bNe6sOcTzw8Iq8sN5mt2-LnEZwkeS_YthZPBxIWrT1H9dDeiW0E4Skw9wt6qAd77NP-QUdjRstLFrYZmeVx_k3K1UCwrUc64SJMCujJaey3kRB2Qk6oGQYsYFBU1RVhoNWgw3-XzZgVyMHD1_AmwryawbQ4sx415oztUi1JTaR5ZQk0QRAOtooltSA8lv6bsi8XBPWCyU=w1242-h931-no
7vyd4JOI8pMqr98iq9p_K5AnBOQOaWGrHWqNxXMtvS21m0ykeRgAsSVMNS8t3VajqcpAtLr5_QjeCHNVNcE_mJrj7kstiDoYu5rb_KLO5XQCtR_lv7o4H7FhZvLR-rMq7Vlacft88ErG8PAfZ8F6aPct1pPNpP7zOTMrhf8bug4bTVJ0yBUcXC4zoqo-MZEx8NPjHeuCvlCG31kjvltPiM2MO5Fz-XGM50G9jPyLa8cuifXStUXDF4t7IH8PQCsBvf1NVmR8q20VOyaDFq3mM2YB7yi-wau8d6B2iDoUGHvlqyTJLR-kDzYKGMCKpUV9dvsEsJHrNSs_8f7RJEZIecaWeM1ynYhR5nYjcWJFUE9S2746y1meiHNSP11zPV7OyTVcXgw1HzTElNIGWUZ7jUwJCaaJJaznL581ISRb-kloUqD1d8isde8kSV4RHOPud5_MId8j-LF9eOIt4d-LEC8WxVZu-XRw3lQP7UkefbgDgBCHEel2hat9vHx1PK-4owp4tIXXLP6V7GL_OYmUo3RHzcNF4nCHVZWDXcbcK5YzD4cdEMlOE9MiJ5LHGTOzQdK0rtozP2YnsOXLd_4bG-HF-Rf__1yYt4dWOm9s_OaZbG9WeEtrA7guU3sUL3Cif8T5b-NrR17gOMSXdTkJLhRZ-iPNNE7RZl49nXyNNdohD3o_loAtGzLYdLL_dyPxn8oFTdSqECqi5DnBsEr9hC2J=w1242-h931-no
RJTZTT5IFqpHCQcqesq7sc5RJ3YMK57T4u5KsJ5X2Ku4_cDlJjl821Y_tf3RjOJyvymk16cXAAhFpiW_vXkObwDssbXhy5T-CqgOwyTj743W-jJvruf8EknGfXt4BGIrTpiXXll-qOL82cpJqa3LMVbeGr1-_jMWMooC603ObHD3ZqzZpw8W5mGClB9aerIp8qGlfFMVXAhOSxXGfk29ie6FtPah5zp9SWt9tVHuEC1b-y44BIFb7DBSj3wSO9LBtVBPHj6l0zGFKTCy9bgfX3haaLfDf9o3bjxMk03MWQagQkttxXTSO-sWZIEn6K0gxJw71T8tdiIsqOoc97ldIWEFgAl4tWUfl6os6KrK61bk1psUsO25nYgwpZLD4OsWYx5c6N3RtYadGCpHzj_tmSVblUKjv7GsiRmyBfkhopgAC9LGepvkNSYc0QnhbxZbARcIJcusshj5rLNDgE-pVV1ChCpp1zBoubmoakAoChoMyIg4W_6QgkBC_05oZbYY5luGEpFxjtQMi2ca9F9nFe6AtmXsbPpKONI6vtO0oyBlD0KH77-94xox3wNAuX9mTttsRdTOI-goDrMD_FUemuMYOgS4vu-B_GUyKysALJJnsTiFCwgY_HWtFtbgzMr8c-qXF3rKM5ppKXCBf35I8_xhLfVQm4sx49StbWC4B9iSmgSZhKhtfi4Z_94sA3IfuQnI8nUP3cx5hTczjq3U3a0Q=w1242-h931-no
sbGf_25W7Nc5Cl-lqtehWsPF5aQEQiRMe-7Dv5jYyRMhEgKFGlB81DTYsST-gYFkjdFiDnOeFxzrDd1C-K51hZ16OFs68hr6S6eODhERUdtFH63iFuQPFZDAvpdgKLV9hVN-2-CKIWX5P_UgI84FDgiovPbKdZz4fKFQU5DObAm_LyI5OsIR281btDgoOgNAJbcvkk72GDLR5I-BJ9P-ndWffGjTkvMbUG7zEvTTu7plvDiVyBkbQiblYg39KZDg4Nk4Xw5y2TBhm25fttBYF1P-27ddp1YhVbuIhFOJUUFxkIMkb1AOF4PF86fapOE3EQk8phItm8SMxuLv2eAWq7Uq0tiyb-9A750RxKD9GrDpRzSfD6j7_gCdiJXcgzi_wDoBuATQszU30rjBRM3O824V2m7WltgDTrLFAW0IB6RYyum1q3R-h4j7JEqRb4Rut2JpS6fsWrcD3MnosWpJ-vrh1194TbXX66GpdWj064dAF7VMLN_INKusExwgn_mDjb7WeTsJ8X4_Ne8aZCMpQkQVgW4zCzhtgV2hMlqLc9ZNY8JsN2iMiTvyATCrIczx5e0bhQFTAxYfQPkmVJl-ZKgEDRmsMFVSt4MluHamHIQRL3qtjQWIlPw-PB1AB-AaYfcNYPRWbqp0Sk206tgqM-jAdIbxNAI9_s1ixb_o0EmkTgA9ClPFuIixIeAMqsnqo7IFFVBtFEe86lbPJUHFLglJ=w1242-h931-no
