[FONT=Arial,Bold][FONT=Arial,Bold]Balancing[/FONT][/FONT]
The Magister, like any other aircraft, must be balanced at a
particular point in order to achieve stable flying characteristics.
Assemble your model ready to fly, and install the flight battery.
The Centre of Gravity (CG) should be about 85 mm from
the leading edge at the root, measured at the fuselage.
Mark this point on both sides of the fuselage. Support the
model at this point on two fingertips and it should balance level.
If not, you can move the flight battery forward or aft to correct
the balance point. Once the correct position is found, mark the
location of the battery inside the model to ensure that it is always
replaced in the same position.
The CG location is not critical - 10 mm forward or aft of the
stated position presents no problems.
Fig. 49
