Altis 4(+)
Heren,
Weet iemand waar ik tegen niet al te gekke prijs een altis 4 extra kan kopen? Namelijk bij wedstrijd in Toldijk heeft mij dit 2 min gekost. Stond klaar met andere kist zonder altis ... :( Dom dom... maar goed daarom weet iemand adressen? Of wil iemand z'n altis kwijt?
Ik ga volgende week bestellen.
Altis V4 is 55 euro
Laat maar weten als je iets wilt hebben.
GJ
Hier de laatste leuke ontwikkelingen.
,met vriendelijke groet Xat
Klik: http://www.aerobtec.com/
30. April 2015
New Altis Line products are here
  • Altis v4+ – innovated version of well known Altis v4
  • Altis GPS – GPS logger with integrated altimeter and rich telemetry support
  • Telemetry Converter – FrSky and Futaba telemetry support for Altis devices
21. April 2015
Altis Flight Manager 4 is here!
The new version of Altis Flight Manager is available, you can download it here.
Telemetry Converter
The AerobTec Telemetry Converter is an extension of Altis Devices: Altis v4, Altis v4+, Altis Micro, Altis GPS. It enriches Altis Devices by new telemetry protocols of Futaba and FrSky. The AerobTec Telemetry Converter selects only the essential from the wide range of information obtained during the flight of the aircraft. The essential information for Altis altimeters is the altitude and vario. The Altis GPS, however, works also with time, date and information associated with the coordinates.
Telemetry Converter
  • Dimensions : 18 x 11 x 5mm
  • Weight : 1.2g without cables
  • Power supply range : 4 – 8.4V
  • Telemetry support for Futaba® S.Bus2 System, FrSky® Smart-Port(S.Port)
  • Compatible with:
    1. – Altis v4+ & Altis v4 firmware version 2.0 and higher
      – Altis Micro firmware version 1.2 higher
      – Altis GPS firmware version 1.0 higher
      – Altis Fliht Manager version 4.0.0 higher
  • Altis Flight Manager
  • Overview
  • Requirements
  • Download
  • Supported devices
  • Screenshots
The AerobTec Altis Flight manager PC application serves to display, process and analyse your the flight data recorded by Altis Devices. Altis Flight Manager is available for free as a software support for ALTIS product line. The Altis Flight Manager allows users to visualize process and analyze flight data in several ways.
Graph view
  • showing measured data into single graph view according to user needs
  • using measuring tools to get specific information about altitude and vertical speed characteristic
  • easy splitting and trimming of measured data
  • altitude and vario filters available to smooth viewed data
  • zooming to show only needed part of curves
  • export to several image and data files
Map/Earth view
  • showing flight trajectory
  • easily moving, panning, tilting, zooming of current view
  • user customizable trajectory look :
    1. – speed points
      – trajectory wall
      – plane mark
  • export KML file
Flight Compare view
  • showing several flight curves into one graph
  • compare various flights from one competition to check your performance
  • compare flight performance between several pilots
  • export image file to show others how you perform
SCREENSHOTS:
Graph view
Map – Earth view
Flight compare view
