motorsports
Forum veteraan
The HK-310 is the new kid on the block at a break through price!
Featuring 2.4ghz FHSS technology, a huge 16 model memory, Detailed LCD Display, an array of user programable features such as Dual rates, EPA, Steering and throttle curves, ABS, timer and many more. The included 3ch HKR3000 Reciever has a bind button so you can say good bye to bind plugs for good!
Features:
16 Model Memory with user programable names
2.4ghz FHSS Technology
Dual Rate
EPA
ST Curve
TH Curve
TH Hold
ABS (Anti-Lock brake)
Timer
ATS (Automatic Start)
BK Mix (Brake Mixing)
Custom Mix
Fail Safe
Neutral Calibration
HKR3000 3ch RX (Included)
Detailed User manual
Features:
Dual Rate
EPA
ST Curve
TH Curve
TH Hold
Timer
Custom Mix
Fail Safe
Neutral Calibration
